prodialog_view.exe - can't find ucore38.dll
pwilliams-3
11-Garnet
Has anyone received the following error when running prodialog_view.exe? WF 5.0 M070 x32 and x64.
[cid:image001.png@01CC7136.6CC7AE20]
Patrick Williams | Engineering Systems | o: 616.698.3766 | c: 616.947.2110
[cid:image002.jpg@01CC7136.6CC7AE20]
Hi Patrick,
I have seen similar errors in the past with other apps. It almost always
boils down to a pathing issue.
Ben
Hi Patrick -
Following up on Ben's comment, I found ucore38.dll here:
<proe_root>\i486_nt\lib\ucore38.dll
<proe_root>\i486_nt\obj\ucore38.dll
These two DLLs are identical; take your pick. They appear
in WF5 but not WF4.
|+| M a r k |+|
Mark Stallard
Rapid Response Development
information Solutions
Integrated Defense Systems
Raytheon Company
(business)
+1.978.436.6016
(cell)
+1.617.331.5443
(tie line)
239.6016
880 Technology Drive
Billerica, MA 01821
www.raytheon.com
Raytheon Sustainability
This message contains information that may be confidential and privileged.
Unless you are the addressee (or authorized to receive mail for the
addressee), you should not use, copy or disclose to anyone this message or
any information contained in this message. If you have received this message
in error, please so advise the sender by reply e-mail and delete this
message. Thank you for your cooperation.
Yea thanks guys. I found them after I sent the note to the exploder. So that dir should be in the path OOTB? Why isn't it?
[cid:image001.jpg@01CC7148.55009FB0]
