"Ghost" Tables
akelly
11-Garnet
"Ghost" Tables
If I have a drawing that uses a drawing format (with tables) or other
drawing tables, I get "ghost" tables on the screen. These "ghost" tables
have the following properties:
* "ghost" tables are visible only on the screen; they are not printed
* If a "ghost" table is present, then it has the same number of cells as an
existing table in the drawing format or in the drawing
* size / scale of "ghost" tables are smaller than format tables and other
draft tables that they are the image pf
* "ghost" tables contain only the cell borders; they do not contain text
* if the drawing has multiple "ghost" tables, size / scale of "ghost" tables
are proportional to each other
* size / scale of "ghost" tables is proportional to zoom (i.e. if the
"ghost" table is 1 in long when the drawing fits the screen, then the
* location of "ghost" tables depends on zoom (i.e. when you zoom in / out,
the "ghost" table does not remain in the same place w.r.t. other drawing
objects).
I can't select any of these "ghost" table on the screen, even when using a
pick-box. I've also tried opening a drawing format and the "ghost" tables
appear in the format, as well. I can't select any of these "ghost" tables
in the format, either.
Any idea what's causing these "ghost" tables to appear. More important, how
can I make them go away? (sample attached)
Wildfire 2003330 / XP Pro SP1 / NVIDIA Quadro FX 500 / 5216 video driver
version
Andrew C. Kelly
Senior Project Engineer
Lear Romec
Tel: 440-326-5555
Fax: 440-284-1090
Be sure to visit our website: www.learromec.com <http: www.learromec.com="/>
The information contained in this message and any attachments is privileged
and confidential. This message is intended for the individual or entity
addressed. If you are not the intended recipient, please do not read, copy
or disclose this communication. Notify the sender of the mistake by
replying to this message and delete this message from your system.
0 REPLIES 0
Attention: Creo 7.0 Customers
Please consider upgrading
End of Life announcement here.
NEW Creo+ Topics:
PTC Control Center
Creo+ Portal
Real-time Collaboration
