Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
Is the readnewermodels.dll file forviewing Wildfire 3 files on Wildfire 2 compatable with 64 bit machines? I've tried putting it on my machine in a few different locations, I've add the config options topobus_enable-yes, atb_show_log-off, atb_auto_check_on_update-off and atb_auto_check_on_retrieve-on as advised on the ptc forum and I still can't get it to work. I've opened the files on WF3 and 4 and they open fine but all our users use WF2 still so I need to get them open in 2 and get them checked into the system. Any ideas?Brandon Lenk Designer TEAM Industries-Bagley (218) 694-4128 <u>-</u>
