Adjusting Format To Fix PDF offset
Level 1
When I save drawing files as pdfs in WF5 it does not save the file at 0,0. Instead the drawing is offset depending on the format that I am using. Is there a way to fix this issue so that when I print as pdf or save copy as pdf the drawing will reorientate so that the drawing can be fully viewed without readjusting the drawing manually?
Re: Adjusting Format To Fix PDF offset
Welcome to the forum, Jeffrey.
I think you are dealing with a catch-22. The size of the drawing sets the size of the PDF and the offset is not accounted for. I have a feeling you will need to create format files that are already offset using a larger sheet size.
I am spoiled in using the Creo 2.0 PDF options. Typically the offsets are only for printers and these are used in the printing routines.
