Can a multiple sections of a paginate 2D repeat region P/L be moved to a different sheet?
Highlighted
Newbie
Pro Gurus:
A 2D repeat region P/L with 9 sections created on sheet 1 using #Paginate,
so an alternate item can be added to the P/L. I am unable to move the any
sections of the P/L to sheet 2 of 8. Here is what I do:
1/ I select the last section (the entire table highlight in red), #edit,
#move item to sheet, #2
2/ The 1st section move to sheet 2 and the remaining 8 sections move to
sheet 3. I notice that the 1st section is always the one to be able to move
to a different sheet.
3/ I repeat step #1 above and try to move the sections from sheet 3 to
sheet 2 to no avail.
4/ Sometime the "move item to sheet" is grayed out and sometime it isn't.
In either case, the sections refuse to move.
The only way I find is to move section 1 to sheet 1 then the other 8
sections will move to sheet 2. However, I am now running into the same
problem describe in step #4.
How do you break the P/L into sections that can be moved to a different
sheet if you run out of space on sheet 1, 2 etc? Is this a normal behavior
of Pro/E Wildfire 3 build M090?
Thank you in advance for your time and help.
