Community Tip - Did you get an answer that solved your problem? Please mark it as an Accepted Solution so others with the same problem can find the answer easily.
X
We currently have WF4 - Creo 1.0 installed and running and need to get Creo 2.0 going. Usually, but not always, a new version means an upgrade to the license server. This doc:
We are currently running FlexNet 10.8. To add support for Creo 2.0, I simply replaced the relevant sections in the existing license.dat file with the new sections from a new license file (with the license service stopped of course). No issues whatsoever.
Tom Uminn Engineering Systems Analyst trans-matic Mfg. 616-820-2499 -<">mailto:->
Doug, I guess I read it the same way as your IT guy. So I Started looking for FlexNET 11.+ for Sun Solaris from PTC - there is NONE. PTC TC confirmed that you do not need to upgrade from FlexNET 10.8 - just swap the license file. It worked.
I was able to do a simple file swap from WF4 to Creo2. Opened LMTools, stopped the server, read the new file, started the server, All OK. Doesn't get much easier than that.
On Mon, Apr 30, 2012 at 2:24 PM, Doug Schaefer < > wrote:
> We currently have WF4 – Creo 1.0 installed and running and need to get > Creo 2.0 going. Usually, but not always, a new version means an upgrade to > the license server. This doc:**** > > ** ** > > http://www.ptc.com/WCMS/files/138523/en/Creo_2_readmefirst.pdf****
