Creo Viewer
mbrorsson
2-Guest
Creo Viewer
I have problem with hidden line removal showing anyway.
I have a STEP file I'd like to make a 2D vector file from.
When I open the STEP file in Creo viewer I choose hidden line removal
and in options Active view/Model-main/Render Mode I disable Display hidden lines as dashed line,
then save as CGM.
When I open in Adobe illustrator the line is still showing.
Does anyone knows why?
I have tried a new installation but still no luck.
-Creo viewer 2.0, M020
Thanks in advace!
7 REPLIES 7
if you can run Creo Parametric, you can create drawing of your model and export it to CGM format.
Martin Hanak
Martin Hanák
Thank's for quick response Martin.
Unfortunately I don´t have access to Parametic just to Viewer.
/Mia
Mia,
I opened pd.stp in Creo View MCAD 2.0 M040 and exported pd.cgm (see attached zip file). Then I included pd.cgm into Word 2010. The result is correct.
You can use my files for testing purposes on your computer.
I guess that your STEP file does not contain solid model. Maybe it was exported as surface model. Can you share this model ?
See How to attach file when you Reply to a discussion.
Martin Hanak
Martin Hanák
Martin,
I think something is wrong when choosing opaque dosen´t seem to work,
it still gets transparent.
Don't know what you mean included into word.
Can't get that to work either.
/Mia
Mia,
1.]
What happens, when you open my pd.cgm in Adobe Illustrator ? Please upload screenshot and add comment describing what's wrong.
2.]
INFO: I am able to insert my pd.cgm into Microsoft Office Word 2010 as a picture.
Martin Hanak
Martin Hanák
My Word is from 2007 waiting for an upgrade .
Your CGM file was fine just as it should look like when opend in Illustrator.
Im not able to get you any of my files sorry, company secrets.
Thanks for taking your time Martin.
I think I'll have to get new softwares for my new computer that soon will show up.
Kind regards Mia
Last comment concerning Microsoft Office Word: Because of security threat, inserting of CGM files is disabled by default. User has to modify windows registry, to enable it.
Martin Hanák
