DWG to PDF using Creo
ks-2
3-Visitor
Hi All,
Is it possible to write a commandline utility to convert DWG file PDF using Creo ? Pl. guide me
thanks,
Kumarappan.S
MartinHanak
24-Ruby II
(To:ks-2)
Kumarappan,
use information located at the end of the attached file.
Martin Hanak
Martin Hanák
David_M
(To:ks-2)
Um, why not just print the DWGs to PDF?
ks-2
3-Visitor
(To:David_M)
Need as a batch file to invoke programmatically from java!
epan
(To:ks-2)
Hi, Kumarappan.S.
As for me, I have seldom tried to convert DWG file PDF using Creo. I wonder have you ever worked it out? Do I need another 3rd party manual toolkit? When it comes to PDF converting process, I have another question, I wonder have you ever tried to convert pdf to other image files before? As for myself, I am testing the related PDF to PNG converting, PDF to BMP converting , and PDF to JPG converting programs these days.  Do you have experience about it? Any suggestion will be appreciated. Thanks in advance.
Best regards,
Pan
MartinHanak
24-Ruby II
(To:ks-2)
Kumarappan,
Martin Hanak
Martin Hanák
