I'm working in WF3, and need to detail the sketches used in the boundary blends that were modeled. I've got the sketches displayed without solid geometry in the drawing and displays perfectly on the monitor, the problem is plotting, either hard copy or PDF.
1. The sketches are missing segments when plotted, how to correct this?
2. The sketches are the default blue and plot dulled (grayscale). Tried tinkering with pen assignments in config file but did not help. Was able to change the system color for sketches to black and this helped, but wasn't sure if there is a better alternative.
Thanks in advance.
