Hello all,
I am having difficulty exporting a particular part that I am working on to a step file.
The part itself is a tubular extrusion of quite a small profile (OD:2.2mm ID:1.8mm) over a relatively long length (2500mm), the part also features a very fine helical cut which runs the bulk of the length of the tube. I have adjusted the accuracy to "Relative 1.0e-04" (that's as fine as I can make it) in model properties given the fine details. When in Creo all looks as intended (see below, the helical cut adds considerably to the regen. time but this I can deal with.
What is problematic is when I export this part to a step file. The geometry appears more like a surface than a solid has some pretty horrible warping running the length of the tube (See below). Ultimately I need to transfer this part to a third party for review and this issue will have to be rectified prior to this transfer, I'm just wondering if anyone else has encountered this problem?
I think you are battling two issues:
1. Part accuracy: Relative accuracy changes the accuracy based on the size of the model. As the model gets bigger, the accuracy gets lower. Change your part accuracy to Absolute 1.0e-04. You may have to change the config option enable_absolute_accuracy to yes.
2. Import settings: Default import settings include Simplify surfaces. To check STEP file, start a new part and set the accuracy to Absolute 1.0e-04. Import the step file and select details for the import profile. Under the Surface tab, deselect Simplify surfaces.
I don't know how the CAD program of your third party will handle the STEP file. A good screen shot of the geometry for the third party to use to verify the import would be recommended.
Thanks for this, when I changed part accuracy to absolute, I was not able to go below "0.0072", therefore Absolute 1.0e-04 was not possible and the lowest on the possible range did not permit a satisfactory level of detail. Incidentally is there a way to increase the range of accuracy?
The import setting adjustment however seemed to do the trick, as you say I will just have to make sure that what the third party imports is as the design intended. Thank you again.
Use these config.pro settings:
enable_absolute_accuracy yes
accuracy_lower_bound 0.0001
There's one more:
default_abs_accuracy 0.0001
Usually the restriction I see when I'm trying to change accuracy from relative to absolute is if a model is kind of old and/or poorly defined. As I make the absolute accuracy smaller it will suddenly trigger a bunch of failed features. That's when the detective work starts...
