Drawing layout is not centered when printed out
mcaoyl2
Dear Progurus,
i am using WF5. I use save as, then select .pdf format to save drawing to
.pdf format. I am using Cute PDF Writer.
However, the drawing layout is not centered after printed out. The layout is
translated to the left and bottom.
Thus, i tried to use publish / pdf. The layout is centered. However, the pen
weight does not follow what i set in config.pro.
And i tried to use publish/print - plot, the preview is ok..however when
printed out...the layout is still not centered.
I am not sure of what else to set. Kindly enlighten me if there is anything
i miss out that caused this problem.
Thank you.
Lily
0 REPLIES 0
