Exporting a step file but also getting all the hidden trim surfaces
Dale_Rosema
While exporting some step files and then importing them, all the extra trim surface that are hidden are coming along with the part. This doesn't work when you are trying to render some parts. Is there a way to have these extra surface remove during the creation of a step file?
1 ACCEPTED SOLUTION
Dale_Rosema
(To:Dale_Rosema)
When exporting a .stp file. Click on the Options button
Then uncheck the quilts and hidden entities
If I save profile, it want to add "def_profile.dep_step"
Where is this file normally located.
This does remove all the extra surface.
3 REPLIES 3
@Dale_Rosema
I think Tom's reply to this post will help you.
Dale_Rosema
(To:Dale_Rosema)
You can save that to any location and set export_profiles_step to read profiles from that directory.
