FW: Is there a way to compare a step file to a part file.
Highlighted
Newbie
Original post:
I am trying to compare a vendor's Step file created in UG to my original
ProE part file.
I made a new part file by importing the step file using :
Insert>shared_data
When I compare solids using : Analysis> Compare Part> By Geometry, the
result highlights the entire part and indicates it's out of the tolerance.
I have played with the measurement distance and Tolerance value, but the
result does not change.
Any suggestions ?
Suggestions:
You might try bringing both parts into an assembly on a common csys and
using the measurement tools. (i.e. surface to surface...)
- Tried this, problem is the part differences are not obvious and
it is very tedius to get surface to surface measurements.
Try CADIQ from Transcendata
http://www.transcendata.com/cadiq_compare_verify.htm
This looks capable
yes assemble them on top of each other
Did it , differences not obvious
It may be that the coordinate systems have to be set up the same way
relative to the parts.
I created the part for the step file import using the original
part as the template.
1 REPLY 1
Re: FW: Is there a way to compare a step file to a part file.
My 2 cents. J
In assembly with two parts paint one part in magenta and second one in
blue. In wireframe mode you can see the difference pretty clear.
Of course I am not talking about the difference in .001 of millimeter.
You can also compare the mass properties of each part ( mass, volume,
center of gravity, etc.)
Best regards,
Igor Varshavsky
Brian Walter wrote:
> Original post:
> original ProE part file.
> Insert>shared_data
> the result does not change.
> Any suggestions ?
> Suggestions:
> and using the measurement tools. (i.e. surface to surface...)
> obvious and it is very tedius to get surface to surface measurements.
> This looks capable
> original part as the template.
> You are currently subscribed to model.
> To unsubscribe send a blank e-mail to
> Don't miss the PTC/USER World Event 2005, June 5-8, in Orlando,
> Florida. Visit www.ptcuser.org/2005 for details.
> For assistance, email us at - or find other
> contacts at www.ptcuser.org/org/contacts.html.
> PTC/USER and the PTC/USER logo are registered trademarks of PTC/USER,
> Inc.
> Pro/ENGINEER is a registered trademark of PTC.
> Message authors are solely responsible for the content of their posts.
