File open filter type shows zip
Highlighted
Participant
When you set file Open Type to e.g Drawing(*.drw) you will also see all zip files. Zip files will always be a part of the list in the same way as folders. Is it possible to "hide" zip files?
Does Creo see zip files as folders?
Highlighted
Re: File open filter type shows zip
Windows sees zip files as directories, so that's what Creo sees them as, too.
