Free PDF writer
Newbie
Free PDF writer
I just installed and tested this on a Proe 2001 drawing and it works great. It uses ghostscript and sets itself up in your printer pick list. Nice!
http://www.cutepdf.com/Products/CutePDF/writer.asp
Gerald Lanz
Design Engineer
Teledyne Brown Engineering
300 Sparkman Dr
Huntsville, AL 35807
256-726-2149
Fax 256-726-2125
RE: Free PDF writer
This works great with WF2 as well.
James R. Barnes
Engineering Services Administrator
CFM US Corporation
1000 E. Market St.
Huntington, IN. 46750
Tel: (260) 356-8000 Ext. 2481#
Re: Free PDF writer
Works with any application, Word, Excel, etc. My experience with XP
when printing many pages at a time was bad, so I've been using PrimoPDF
with good results.
Rui
> *James R. Barnes*
> *Engineering Services Administrator*
> *CFM US Corporation*
> *1000 E. Market St.*
> *Huntington, IN. 46750*
> *Tel: (260) 356-8000 Ext. 2481#*
> *Fax: (260) 356-2936*
> *Email: **jbarnes@cfmcorp.com*
> The information contained in or attached to this email is intended only
> for the use of the addressee. If you are not the original intended
> recipient of this email, or a person responsible for delivering it to
> the original intended recipient, you are strictly prohibited from
> disclosing, copying, distributing or retaining this email or any part of
> it. This email may contain information which is confidential and/or
> covered by legal, professional or other privilege under applicable law.
> If you received this email in error, please notify the sender
> immediately by return email and destroy all copies of the information
> contained in or attached thereto. Thank you for your cooperation.
> The views expressed in this email are not necessarily the views of CFM
> Corporation or any of its divisions or affiliates, and the said entities
> and their respective directors, officers and employees make no
> representation, nor accept any liability, regarding its accuracy or
> completeness, unless expressly stated to the contrary.
Re: Free PDF writer
For those interested-
This is slightly off topic, but nevertheless related to PDF writers and printing in general.
There is a software called "fineprint" (www.fineprint.com) that works great with many standard applications (I've printed Pro/E files too..). It adds itself as a printer.The beauty of the software is that you can 'nest' pages when printing documents, thus saving valuable paper. For example, if you have a 50 page powerpoint to be read, you could nest 4 or 8 ppt slides in a single page and print them out. Or say you have a word document that has to be reviewed by others- just put 2/4 pages 'per page' and print them out! I routinely use it check/distribute/review draft versions of documents.
Besides, it also has a PDF writer (with the same nesting feature) which means you can nest as many pages you want and turn a pdf out of that nested page. Only downside being for freeware versions, files have a line below the page that says "printed with fineprint". But its a small price to pay for a set of nice features [think of all the trees you'll be saving]:).
have a good weekend all!
Jaya
pS: You need to download and install "fineprint" & "pdffactory" (each ~2.5MB)
