Good Triangles from tessellation..
Newbie
Hi Guys,
We have tried to get good triangles generated from
ProPartTessellation and ProFemmeshExport APIs, but without any success.
The generated triangles are really skewed, with largest side being
10-100 times shortest side. ProFemmeshExport gives better results but
mesh controls can not be set programmetically and require Pro/MESH
license.
My current requirement is to get good triangles with minimum changes in
side lengths. You can set chrod height and angle control, but there
seems to be no way of controlling step value.
Do you have any previous experience or solution, suggestion on this?
Thanks in advance,
Himanshu Nayak
Senior Software Engineer
Geometric Software
Re: Good Triangles from tessellation..
Himanshu,
Wildfire 3.0 contains TOOLKIT functions for Pro/Mechanica integrated mode
including mesh controls. As you stated though, a separate Mechanica
license is required.
Michael
Himanshu Nayak wrote:
> Hi Guys,
> mesh controls can not be set programmetically and require Pro/MESH license.
> there seems to be no way of controlling step value.
