I am using PTC Creo Parametric 2.0 and I really need to edit an .igs file!
I can import it and open it but i cannot modify the geometry or like modify the original sketch...I am just able to move the parts.
What I need to do is to create another sketch over the geometry and the 3D I import, cause I need to draw and add another "piece" to it.
If anyone knows how to do it please reply!
Thanks in advance
Hello and welcome in forum.
One of many possible way that l know is edit iported geometri directly in Creo. See pictures belowe, that represent editing iported feater in assembly and part level.
Assembly options:
Part options:
l hope it can helps you...
