Help! special characters not printing right. ± ≥ ect.
SOLVED
Participant
I hope someone has an answer for me.
Im trying to make a standard frame for my company and im notacing that when I print to paper or PDF the special characters drop down half a letter height.  so 6≤X<30 is aligned like -_----  .   It looks fine on screen and it doesnt seam to matter what the font is.
I would realy like to do this correctly and not just have an offset cell for the special characters so that wen it wrongly prints them they are in the right spot.
Please someone tell me that other people are having this problem and that there is a solution.
Im running the latest version of Creo on win10, using foxitPDF and a generic office printer with the same results.
PDFPDFScreen DisplayScreen Display
Re: Help! special characters not printing right. ± ≥ ect.
Did you tried using "Stroke all fonts" on saving drawing as PDF (File > Save as > PDF > Options > Content Stroke all fonts). Are you using default fonts in Creo drawing.
Thank you very much. stroke text worked wonderfully.
