GB, unfortunately and to the dismay of many, the Help Topic Collection for WF5 does not exist.
Regards, Jim
In Reply to georges bon:
Hi everybody,
In the pass, I used to download and search informations in Help topic collection.
It was a complete set of pdf help files.
I don't have maintenance anymore but last time I looked, it didn't exist for Wildfire5 (Creo did not exist at this time).
So, can someone tell me if this file "help topic collection.zip" is now exist for WF5 / creo elements ?
I found this very helpfull and I would apreciate to have this for last revision of ProE.
GB
The Help Center that is within Creo Elements/Pro is available online, just not as a PDF document. http://www.ptc.com/cs/help/proengineer_hc/proe_help/ You can access it from the Pro/ENGINEER and Creo Elements/Pro Support Center oon ptc.com. One benefit you get with thisis always having current information. With this you can open it outside ofCreo Elements/Pro ona second monitor if you wish. Youget full functionality of the Help centeras if youopened it fromPro. I strongly recommend a user take the time to reviewthe "Using the Help Center" linkto benefit from all of the new functionality the revised Help Center brings. Now if PTC could only add the ability to use the LearningConnectorfrom the online Help Center it would really add power to the user.
