Help
Newbie
Help
Does anyone have any info about synchronizing of sequence for 2 turrets and also about flashing of tool in turning.
Any site, video, pdf .. will help.
Prashant S Kapse
Help
Pro/NC Experts;
I'm trying to add a custom CL command to the menu under the Sequence > Customize. I can create a cmd file for each option and load it by file, but we want to have them available from the menu. I see def files and syn files in the cmd_syn directory. The syn files look like system generated files. Suggestions?
Best regards,
Michael Braaten
PLM/CAX Systems Analyst - Synthes
Help
Mike,
This is one of my favourites in Pro/NC... you can compile syn files that they will appear in the cmd menu... great stuff... please refer cmd_syn directory in the help.. there are some topics about that and how to use the ptc compiler... just be sure to use the compiler with the option -i and it will work... place the files at the cmd_syn directory, re-start pro/e and they will be there... 😉
HTH
Daniel
