Community Tip - Did you get called away in the middle of writing a post? Don't worry you can find your unfinished post later in the Drafts section of your profile page.
X
How do I retrieve an "AS STORED" revision iteration from Intralink history files
I need to go back in time..... on a drawing and model within Intralink to re-create a pdf file of an older revision for historical purposes. Every time I check out the revision iteration I want, all the parts inside the assembly are current, not AS STORED for that iteration. What I want is everything as it was (AS STORED) for that older revision. I haven't done this in ages but the last time I did there was an option to retrieve an AS STORED version. How do you do that on Intralink 9.1?
Does any one know how to do this in Creo Parametric 2.0, date code: M010 with Intralink 9.1 date code: m070
Any help is much appreciated,
Reichert Technologies Connie Cooper-Szymczak Design Drafter II - Document Control TEL: 716-686-4576 | FAX: 716-686-3150 | connie.cooper@ametek.com
AMETEK ULTRA PRECISION TECHNOLOGIES 3362 Walden Avenue | Depew NY 14043 USA | www.reichert.com
