How to open .dwg file in Creo 2.0?
SOLVED
Newbie
Hi
I want to open a .DWG File which is made in autocad 2011.
But when I open it,It give me "Invalid DWG file" message.
Can you please share step by step process to open DWG File.
Re: How to open .dwg file in Creo 2.0?
Nikhil,
according to https://support.ptc.com/appserver/cs/view/solution.jsp?source=subscription&n=CS134024:
  • Creo 2.0 supports AutoCAD import up to 2010
  • Creo 3.0 supports AutoCAD import up to 2013
On the other side AutoCAD 2011 uses the same native file format as AutoCAD 2010. See http://autodesk.blogs.com/between_the_lines/autocad-release-history.html
Therefore it is difficult to say, what is going on. You can contact PTC Support, if you want.
Martin Hanak
Martin Hanák
11 REPLIES 11
Nikhil,
Martin Hanak
Martin Hanák
The easiest & fastest workaround for this is to save in a earlier version of autocad(save as -> files of type[change here]).
Hi All,
I want to open simple .dwg file in creo.
Is it possible to show me step by step process.
Here I attached snap to open .dwg but I give me error.
Nikhil,
can you upload your DWG file ? See How to upload Creo (or other) files
If it contains secret info, can you provide some test file ?
Martin Hanak
Martin Hanák
PFA File
PFA Drawing File
Second file
Martin Hanák
Hi Martin,
Can you please check and let me know.
Nikhil,
if you open BRDC1-C.dwg or Drawing2.dwg in Notepad and check first six character, you will see AC1027 code. This code tells us, that DWG format belongs to AutoCAD 2013, 2014, 2015. Therefore you cannot open DWG files in Creo 2.0. Creo 3.0 opens files successfully.
Martin Hanak
Martin Hanák
