Impact Mapkey Software?
Highlighted
Newbie
Hey Folks
Does anyone know where I can get a copy of the old Impact Mapkey
software?
I've searched the web with no luck. Or better yet, does anyone know if
there is a new and improved automated mapkey execution software out
there, especially one that might run within Intralink?
If you have no clue what I'm asking for, the Impact software would allow
you to choose a whole bunch of Pro/E files & run a mapkey on every file.
My prime example (and need at the moment) is that I have a PDF mapkey,
and I have 100+ drawings. With impact I could select all 100+ drawings,
tell it to execute the PDF mapkey on each drawing, and after a few more
mouse clicks, I could sit back and watch Pro open each drawing and
create a PDF file of each. As fast as the computer could go... it was
quite fun!
I had a copy of this at one time (obviously) but can not lay my hands on
it.
Is there anything new out there I should look at?
Thanks!
Martin T. Brown
Spallation Neutron Source
Voice 865-574-4818
Rm# J-319-F CLO
4 REPLIES 4
Highlighted
Martin,
If you have a pdf print driver installed on the machine you could use Pro/Batch
(look for the pro_batch.bat file located in the bin dir for the pro/e install)
another mapkey software you might take a look at is workspace macro pro 6.5
Highlighted
Martin,
I believe Spekan batch will do what you want.
This is to only download site I can find for it:
Highlighted
The latest version of Spekan batch can be downloaded from the following
website.
Highlighted
Why not use Pro/Batch, Ghost Script and Freedist.
I just created 200 PDF files.
Here is a good link if this quest is all about PDF.
