Importing CATIA Files into Creo
DAVID17
Community,
I import CATIA a file into Creo Parametric and I'm able to open it but the geometry doesn't looks good, it shows as a surface not a solid and also some surfaces are not connected (that's why is not a solid) when I review it on CATIA it shows as a solid, I try it with a native CATIA file and a step file and I have the same issue.
Any idea or suggestion?
Regards.
BenLoosli
23-Emerald II
(To:DAVID17)
Accuracy settings may be causing gaps to the imported model.
How complex is the CATIA model?
How many features?
What versions of CATIA and Creo?
Yes, I had been playing with the accuracy, It improves but I have not found the correct number.
It's complex, It's a full roof assembly has some details (fillets, etc) that are the surface issues I see and also some surface joint issues, I keep trying to work separate with each part to see if I can solve it,  The version of CATIA is V5 (2018) and Creo 4.17.0, I don't have CATI software to see how many feature they are, I request to the team share the CATIA file this information as soon as possible I got it I will share it.
Regards.
