Measure Tool in Creo 2.0
Re: Measure Tool in Creo 2.0
We still haven't made the giant leap to releasing work through Creo even though we have a lot of time spent in learning the software.
I have a couple comments to add to the discussion.
1) Without question the measurement tools are confusing to learn; sometimes you wonder whether you can even get from point A to point B. In the software we are replacing it is so simple and straight forward to get measurements. Why do they add so many layers of confusion?
2) Why is it that you don't see feedback in discussions like this from the product developement team. Brian is totally dependent on this software; and he represents many seats of Creo. At what point does the developement team care about how people actually use the software and why it is considered so unintuitive?
I like threads such as this as there are good ideas in how to make the best of confusing tools within Creo.
Paul,
Look at how many users are complaning out LOUD about this tool. A few. Therefore, no one from PTC will even blink their eye because of us. If the number would be at least 1000, then they would start listening. Until then, we have to live with it, like it or not.
I guess one of the dissillusioning things we ran into when making our switch was thinking that a company with greater resources such as PTC would equal greater responsiveness.
I do hope better days will follow.
Paul,
I'm interested on why you find this tool confusing. It's extremely simple to me - select measure, select item one, hold ctrl & select item two. You get a variety of data depending on the itmes you've selcted. You do have to expand both areas of the measure dialog box (something that should be expanded by default, IMO), but behond that I'm not seeing layers of complexity. Can you elaborate?
LinkedIn
Doug, the fact that you need to know to choose a CSYS to get simple X, Y, Z data is something you have to get use to. This is the primary use I have for the measure tool. Not two clicks (and having to hold the CTRL) but three. This is not obvious on 1st opening the measure tool.
Doug
Brian gives a very good example of this where he lists the 9 steps needed to measure plane to surface or surface to surface.
I'm glad that you can use the tool without difficulty; perhaps it all will make sense in time. Part of it is what a person gets used to. I guess I'd still prefer doing the same operation in 4 steps. Inquiry/Surface to Surface/Select 2 surfaces.
I'm very green at this software yet I've seen it surpass the software I still use in some of it's capabilities. Still I hate how cumbersome it is.
I've been using Pro/E for 17 years and I believe you've always had to choose a CS to get X, Y, Z data.
LinkedIn
That explains why I never liked using the measure tool in any version of Pro|E
Not to get too picky, but much of the difficulty Brian lists has to do with long standing issues with the selection method in Proe / Creo, not really the measure tool. I agree with him on that point, query select should give me the nearest item first, the next nearest second and so on. It doesn't adn if it did, that would make measuring much easier.
You can set your selection filter at the bottom right of the screen from 'All' to 'Surface' which would help.
I've used Proe / Creo since 1996, rev. 16. The measure tool in Creo is a significant improvement compared to what we had before.
LinkedIn
Those of you with maintenance, please vote on this idea:
http://communities.ptc.com/ideas/1026
Message from Brian Thompson (PTC General Manager and DVP) regarding Creo Business Continuity plans.
