Nvidia Quadro 4000 Vs K4000
ybhide
1-Newbie
Greetings,
Anyone experiencedproblems usingNvidia Quadro K4000? In PTC's certified/supported list, K4000 is listed more often than 4000.
http://www.ptc.com/WCMS/files/138217/en/hp_creo2_p10.pdf
But I came across article about performance degredation when switching from 2000 to K2000, so was wondering if that is case with K4000s too.
https://www.ptc.com/appserver/cs/view/solution.jsp?n=CS131057&posno=1&q=quadrok2000&nav=ptcproductgroups||creo||Product+Group||Creoou!
Thank you!
Yugendra Bhide
Norse Dairy Systems
Columbus OH
3 REPLIES 3
StephenW
23-Emerald II
(To:ybhide)
When we were testing video card originally. We noticed the higher end cards were actually slowing things down. Our IT guy with through several fixes and finally figured out it was the CHIPSET drivers that needed to be upgraded. The motherboard was not allowing the video card to process as fast as it should or really it was bottlenecking the video card input to the motherboard. Once we upgraded the chipset drivers, performance improved significantly.
dgschaefer
(To:ybhide)
What is the difference, if any, between video card drivers and chipset drivers? How does one find what chipset driver is being used and where do I download new ones, assuming it's not the same as the video driver from Nvidia?
LinkedIn
StephenW
23-Emerald II
(To:ybhide)
Well, I had no idea until it came up again the other day. The video card driver handles the video card and it's stuff. The chipset driver is for the motherboard, as it was explained to me. The motherboards come set up a certain way and then when new hardware comes out on the market, they need a new driver to properly access the hardware. I was told you have to have access to the bios to upgrade the chipset drivers, something I will not even try, I'll leave that up to the IT guys. I don't have the will to BRICK my computer.
I googled it to get a little more info once it was explained to me.
I assume you get chipset drivers from the motherboard manufacturer or from the computer maker (HP, Dell, eMachines (haha, if you still use an eMachines computer))
