First post on here, hello all.
I'm having difficulty changing the colour of dimensions on a drawing.
I want the exported dimensions to be blue, 0,0,255.
I've created the config.pro file, also created pen_table.pnt shown below:
! PEN TABLE
!(GEOMETRY, VOLUME) edges, volume
pen 1 color 0 0 0; thickness 0.05 cm;
!(LETTER)
pen 2 color 0 0 255; thickness 0.01 cm;
!(HIDDEN)
pen 3 color 0 0 0; thickness 0.01 cm;
!(HIGHLITE)
pen 4 color 0 0 0; thickness 0.01 cm;
! "Sheetmetal"
pen 5 color 0 0 0; thickness 0.01 cm;
!(SECTION)
pen 6 color 0 0 0; thickness 0.01 cm;
!(DIMMED)
pen 7 color 0 0 255; thickness 0.01 cm;
!(EDGE_HIGHLITE_COLOR) text
pen 8 color 0 0 0; thickness 0.01 cm;
I've set pen 2 to 0,0,255 for blue but when I export to PDF it opens in black.
I'm abit of a novice to the advanced side of this software but i'm getting there. I have searched around but nothing has worked.
Hope someone can help with this.
Cheers
add following options into config.pro file
pdf_use_pentable yes
use_8_plotter_pens YES
color coding you put into pen table file is not correct. RGB values must be real numbers from interval <0.0, 1.0>.
Please test following line
pen 2 color 0.0 0.0 1.0; thickness 0.01 cm;
Not sure if you are using a CAD worker or just doing this on your desktop. But the pin table updates and config.pro settings would need to also be on the CAD worker.
