Creo2 and Windchill 10.1
I create a PDF file using "save as" command.
If the model is in "released" state ( and also with green semaphore ) the operation stops and the PDM Conflict window appears
in which the system asks me to change the state of model ( continue, read only ,...) to continue .
But who knows that if it's possible to avoid this stop ?
There is not this problem if I use "print" command with virtual pdf printer
Thanks in advance
