Part Patterns in Assemblies
cgoshorn3
6-Contributor
In an assembly, how do you create a pattern of three (3) parts at once, for exaplme; a bolt, nut and washer, can all three be selected and a pattern of all of them be selected and a pattern created, or is there a copy command that will work better, please give step by step solutions, for us beginners.
StephenW
23-Emerald II
(To:cgoshorn3)
Group the parts using right mouse button.
Once grouped, you can pattern together or you can use copy.
Sergey
(To:StephenW)
Hello.
Thanks, it worked well.
You can also store the combination of components as a User Defined Feature (.gph file) to place over and over again. This will also appear in the Model Tree as a Local Group.
IFX is also pretty good at allowing you to place combinations of fasteners in a pattern of holes.
Dave Martin - dmartin@creowindchill.com - https://www.mcaeconsulting.com
