& share any Windchill Workspace manipulation Tips and Tricks you have.
Creo 2 tips, you have
removing and item is a pain
Updating out of date parts is a pain
Sorting is a pain
is it a known bug that the scroll bar vanishes and it decides to only show
you 12 out of your 332 items in the workspace? (and no I didn't add a
search filter, all I did was try to bring the out of dates to the top)
Why did they decide we didn't need WHERE USED??
Can these columns be made wider?
Do I really have to UNDO and REDO a check out to transfer something to
another workspace?
I have an assembly to import in as a step, when I used FILE OPEN it doesn't
all come in as solid, when I try to use the IDD all it will let me do is
adjust the gap size ..
I need to adjust the accuracy, but when I try to start from an assembly and
import this is what I see,
notice that even though ALL FILES is the default it does not show me my stp
files
(yes there are about 20 in that folder) & it doesn't give me the option
to change that to step
I have a part that is locked by another user, I will be using the same
group of features on my part and want to copy them, but when I open the
part I can't do anything to it, I can't even see the model tree.. Does the
file have to be unlocked for me to copy from another part? (can I even
still copy features from another part?)
I'm sure I have a million more questions but these are todays
Frustrations. I'm leaving now, and I'm going to stop and buy myself
something chocolatey ..
Thanks in advance
Terry
