anonymous wrote:
That the error would be in the print driver I doubt. Connsidering if I use other programs prints are accurate.
I know this is too little, too late for wportegijs, since the original thread was almost a year ago, but I have had the same problem, and have found a resolution. So hopefully this will help anyone else with the same issue. For some reason, when you select the "Factor" radio box, it does not stick. If you go back and print that same thing a second time, you will find that it has reverted back to "Fit" again. You have to actually click in the "Factor" field and hit enter. I think
wportegijs found that when he entered a scale of 0.9999..., he got what he wanted. Even if you just click in the field and hit enter to keep the 1:1 scale factor, it will stick. You will get an error message saying something about the maximum scale factor, but it will still print correctly.
