~hi all,
Ok, I'm drawing a blank on this (no pun intended...)
WF4 M130 (yeah yeah.. it's old..)
Anyway, from a drawing with sketched points (draft item), when using File -> Save a Copy -> PDF -- the points do not "plot" to the PDF file. What setting am I missing?
tia
_mark
In Reply to Mark Rafn:
~hi all,
tia
_mark
Here's the solution for others that may have the search...
Here is the reason that your points are not showing in the PDF’s . . .
The default value is No
