If convert a drawing file to pdf the dimensions are getting distoreted.
Help me in resolving this issue.
Dhinesh
Distorted in what way? Is it a font problem? May I suggest using the option in the image attached ("strike all fonts" in the Contents tab). It might help but it may make the resulting file bigger in size.
Abdul,
Dimensions are getting distorted in a way that the witness lines are getting moved away from the reference edges.
The offset value applied for the witness lines is getting increased or decreased once I publish drawing to pdf
Dhinesh
Dhinesh,
try to use PDFCreator to generate PDF.
Martin Hanak
