RE: Global Ref Viewer - WF2 - summary
Highlighted
Guest
Gurus,
1st response:
I believe if you add a status column to the model tree a least the frozen
and partially frozen features and components are flagged.....Thank you.
The solution I was looking for is an old 2001 Mapkey that is still working.
But I'm not able to define it again.
PTC you have lots to do !!! Count your mouse clicks...
For the Mapkey-Freaks:
1st time open the Global Ref Viewer with:
mapkey ud_grv @MAPKEY_LABELGlob Ref;\
mapkey(continued) ~ Select `main_dlg_cur` `MenuBar1`1 `Info`;\
mapkey(continued) ~ Close `main_dlg_cur` `MenuBar1`;\
mapkey(continued) ~ Activate `main_dlg_cur` `Info.psh_info_ref_viewer`;\
mapkey(continued) ~ Move `erm_main` `erm_main`2 9.251222 0.000000 ;\
mapkey(continued) ~ Resize `erm_main` `erm_main`4 9.251222 0.000000
25.564027 22.963832 ;\
mapkey(continued) ~ Move `erm_main` `Sash4`83 ;~ Select `erm_main`
`MainMenu`1 `TreeMenu`;\
mapkey(continued) ~ Close `erm_main` `MainMenu`;~ Activate `erm_main`
`ColumnsPushBtn`;\
mapkey(continued) ~ Select `ervcolumn` `ListName`1 `Feat Number`;\
mapkey(continued) ~ Activate `ervcolumn` `AddBtn`;~ Activate `ervcolumn`
`AddBtn`;\
mapkey(continued) ~ Select `ervcolumn` `ListName`1 `Copied Refs`;\
`OKBtn`;\
mapkey(continued) ~ Move `erm_main` `MainRefViewTree`31 ;\
mapkey(continued) ~ Select `erm_main` `MainMenu`1 `TreeMenu`;\
mapkey(continued) ~ Select `erm_main` `MainMenu`1 `ActionsMenu`;\
mapkey(continued) ~ Select `erm_main` `MainMenu`1 `FileMenu`;\
mapkey(continued) ~ Select `erm_main` `MainMenu`1 `FileMenu`;~ Close
2nd step: if the Global Ref Viewer is open with the needed columns use the
2nd mapkey to filter:
mapkey ud_tr_search @MAPKEY_LABELGlobRefFrozen...;\
mapkey(continued) ~ Move `erm_main` `erm_main`2 9.223851 0.000000 ;\
mapkey(continued) ~ Resize `erm_main` `erm_main`4 9.223851 0.000000
25.564027 25.892473 ;\
mapkey(continued) ~ Move `erm_main` `Sash4`91 ;~ Select `erm_main`
`ColumnsPushBtn`;\
mapkey(continued) ~ Activate `ervcolumn` `RmvBtn`;~ Activate `ervcolumn`
`RmvBtn`;\
`AddBtn`;\
mapkey(continued) ~ Activate `ervcolumn` `AddBtn`;\
`ApplyBtn`;\
mapkey(continued) ~ Activate `ervcolumn` `OKBtn`;~ Select `erm_main`
`Search`;\
mapkey(continued) ~ Select `erv_query` `ValueList`1 `Frozen_place_s`;\
mapkey(continued) ~ Activate `erv_query` `AddBtn`;\
mapkey(continued) ~ Select `erv_query` `ValueList`1 `Independent_s`;\
mapkey(continued) ~ Select `erv_query` `ValueList`1 `Excluded_s`;\
mapkey(continued) ~ Select `erv_query` `ValueList`1 `Frozen_s`;\
mapkey(continued) ~ Select `erv_query` `ValueList`1 `Suppressed_s`;\
mapkey(continued) ~ Select `erv_query` `ValueList`1 `Missing_s`;\
mapkey(continued) ~ Activate `erv_query` `AddBtn`;~ Activate `erv_query`
`TreeFilterBtn`1;
PTC again: count the unbelievable mouse clicks again and think about large
assys, parts with 1000 - 2000 features and think about, that we are earning
our money with your tool. You should collaborate...
Regards Uwe
_____
