REVISION MANAGER
mekins
REVISION MANAGER
Hi ,
Is there any option in Cre-o to save an assembly into desired folder without using save as option.
Similar to Revision Manager in Solid Edge Software.
in case that you created new assembly Creo will suggest you to save it into current working directory. You can change target directory.
Martin Hanák
mekins
(To:MartinHanak)
Dear Martin ,
If I have created many parts , in  which some of the parts are not used while creating Assembly.
Then how can I save that Assembly to separate folder without using save as option.
Raghu
unfortunatelly I do not understand what you need. Please provide more detailed explanation.
Martin Hanák
mekins
(To:MartinHanak)
Dear Martin ,
Once check the attached video .
Raghu
I am sorry I do not have time to study REVISION MANAGER functionality.
If you want some advice, please describe your situation when working in Creo.
1.] what are your source data
2.] what do you want to get
Martin Hanák
