STEP Turn into surface. Double sided edge fix
atilas1
I have file from client that creo imports as surface. With IDD I found out there are a few edges that gives "Bad two-sided edge" it also gives a solution, that says use the"Merge Crv/Wfm". Where could I find this tool?
1 ACCEPTED SOLUTION
in Creo Parametric 2.0 M070 I did following actions:
1.] When I opened captofix.stp, I set using External accuracy
2.] I edited definition of import feature and went to IDD mode using following button
3.] I clicked Repair button and set Reair Tangency option
4.] Finish Repair action using green check button
5.] Close IDD mode using green check button
6.] Click Solid import button and green check button to finish Edit Definition
7.] Solid model is available
Martin Hanák
7 REPLIES 7
Martin Hanák
atilas1
(To:MartinHanak)
Hello Martin,
Thanks for informative reply, however, that was first thing that I did and most of the time it worked for me as well. However for this model it doesn't. When I go into geometry check it shows for me a few problems that repair doesn't fix. I usualy ignore Bad vertices, it seems creo handles them well. However other two types of problems I don't know how to resolve.
unfortunatelly I do not know how to deal with IDD geomchecks.
Do you use commercial -OR- education license ?
What Creo version do you use ? I can test model repair in it and send you the resulting model.
Martin Hanák
atilas1
(To:MartinHanak)
I use commercial license.
Creo 2.0 M230. This question is more about know how then the model itself, because I have a few more models like this and trying to find out how to fix them all.
I installed CR2 M230 and followed procedure published on 2017-09-08 01:58 PM. Resulting model is attached.
Note: I hope you know that every imported model needs special healing procedure.
Martin Hanák
atilas1
(To:MartinHanak)
Could you provide more information about said healing procedure? It might be the thing I'm looking for.
I think I provided enough details in my reply from 2017-09-08 01:58 PM
Martin Hanák
