SUMMARY - import step with start parts
ptc-1140334
THanks to all for a quick response!
Here is the consensus,  all responses had the first setting, Doug is the
only one who included the template location setting.
Have a great weekend.
Eric Henriksen
Entegee Engineering
Davenport
> Yep.  Set this config option:
>      intf_in_use_template_models yes
> It'll then use your default start parts/assys as set in these options:
>      template_designasm [path to start asm]
>      template_solidpart [path to start part]
> Doug Schaefer
Another good reason for doing this, you can have a template with higher than
normal accuracy. This can be critical to the proper importation of models
that have both large and small edges.
