Save as PDF problem
Newbie
Save as PDF problem
I am using WF3 build M020. I have noticed a problem with the save as PDF
function in Pro/E. I have had a number of drawings where there a good
number of missing lines and for one drawing everytime the two times I
tried to use the save as PDF function, Pro/E crashed out. I was able to
use the PDF995 printer driver with and see all the lines that were
missing from the PDF that Pro/E creates. Has anybody else noticed this
problem and is there a solution? The work around of using the PDF995 is
not as good as when the save as PDF works, the output is much better
than the PDF995 output.
Thanks;
Peter Stockhausen
Mechanical Designer
Pollak Switching Products
This electronic mail transmission contains confidential information
intended only for the person(s) and/or organization named. Any use,
distribution, copying or disclosure by or to any other person
outside your organization is strictly prohibited. If you received
this transmission in error, please send an electronic mail message
to postmaster@pollak.com so we may instruct you regarding its
disposition.
