Skip STEP import error messages
SOLVED
Newbie
Hi!
We offten import quite big models in the STEP format. The models have many errors, but are usually not important to us. Now we have to sit at the computer and click on every error mesege to continue importing the file.
Is there a way to skip all the error messages when importing files?
Tags (3)
Re: Skip STEP import error messages
hello,
Yeap there's a way, set the following option in config.pro
show_geom_checks_on_creation no
hello,
Thank you for your help! You saved us a ton of time.
This has saved me a lot of time.  Thanks,
