Does anyone know of a way to convert a large database of step AP203 files to A214?
you can generate trail file, which will load the STEP AP203 files and then export them to STEP A214 format (one by one). Unfortunately, this procedure can lead to geometry errors in STEP A214 files.
Also you can use PTC Distributed Batch tool.
