Translate components in imported step assembly
davehaigh
11-Garnet
I've imported an assembly of a equipment rack. I need to move some of the components in the rack.
I don't really want to have to create assembly constraints just so I can move a couple parts.
Is there something like draft translate where I can move the component an x,y,z distance from its current position?
David Haigh
Phone: 925-424-3931
Fax: 925-423-7496
Lawrence Livermore National Lab
7000 East Ave, L-362
Livermore, CA 94550
I got a couple answers. After some emails back and forth I think I have the solution. Not pretty, but it works.
In my case I'm trying to move a sub assy. So the first thing I had to do was pick the sub assy and edit definition on it.
I had to change the constraint type to Fix
[cid:image001.png@01CFB22F.03CFF0C0]
Then you can do the following:
* From the Model tab,
* Component pull down, select Component Operations,
* pick Transform.
* Select a coord sys. Select the component to move.
* Pick Translate,
* z axis, or any other axis
* enter a value,
* Done move
* Done/Return
* Regenerate the assembly At that point the item moves.
David Haigh
