Has anyone found a True Type or Open Type font that matches the default one (Font) in Pro/Engineer? I ask this because we have existing drawings don't desire changing the fonts to something else, and would benefit when creating PDF files.
Have you tried checking Stroke All Fonts when creating the pdf? This will keep the font the same as you see on screen.
Below is a summary of the responses I received from asking a similar question in 2008:
In Reply to Jason Williams:
I started to look into this as well about a year back. One thing I did notice was that all of the fonts that shipped with Pro/E were files that described how to draw the lines. That is why the standard "font" does not have greek characters.
Because of how these "fonts" are created, I do not think you will be able to find a good match. That said, you could look at Lucidia Console/Lucidia Mono (ships with Windows) or Liberation Mono (ships with Redhat, available for download for free). There are other monospaced fonts out there, some free and some not, that might be closer.
-Lawrence S.
