PTC does not support 3.0 when used with Win7 so I'm hoping someone here can help. Has anyone else had issues with the PDF
Publisher not working in Win7?
S Pfahler
Do you have the 64bit Windows 7? I have noticed that PDF is not available in WF3 in 64bit but is in 32bit. I have found that I have to work on the drawing then switch to a 32 bit system to create the PDF. It was this way on all the releases of WF3 that I tried.
I have not had a problem with PDF publishing in Win7 32bit.
I think it is possible to install and use ProE WF3 32-bit in Windows 7 64-bit.
Martin Hanak
