Adding a right mouse button wheel
mlinetti
Hi, i'm learning to use creo direct for work and i come from solidworks.
On solidworks (and every 3D program) i use a lot the rapid views (front, side, rear, top etc...) by using this selection wheel that appears with a right mouse button click:
Can i add something similar to creo direct? with a plugin maybe?
Thanks.
1 ACCEPTED SOLUTION
such a function does not exist following my knowledge.
But you can use the "Command Mini toolbar" inplace.
That can you adjust in ->file ->options, see pictures.
There you can add every command that you want.
Best regards
(Please write info in your Signature) Sysinfo: I use Creo Elements Direct /Drafting, /Modeling and /Modeling Express 8.0 ( formerly CoCreate- SolidDesigner and Drafting or ME10 )
mbonka
(To:mlinetti)
Hello Mattia Linetti
don´t know any "addon" like this.
l´m using 3Dconnexion mouse and there is something similar when press button on this mouse. But it´s only about model orientation.
3Dconnexion : Start
Regards
Milan
Best regards
mbonka
(To:FriedhelmK)
Something new for me...
Thanks for great question and useful answer...
Thanks both guys.
I'm using a 3d connexion mouse too (space mouse wireless) but i prefer to use the 2 buttons on the mouse for blocking rotation axis.
The Command mini tollbar it's the best way to do it and it's similar to the solidworks wheel, i'm going to add the views and use it.
