Good day to all...........
Can anyone tell me if it is possible to add common notes to a .frm (to be used as a start format format for new drawings) and subsequently alter the notes while in the .drw? At this time, I am creating symbols that we pull in and alter, but I'd like to have several notes and other nomenclature already on the drawing via the selected .frm.
Thank you for your consideration - Brian
I would use a drawing template for this. Text outside a table in a format is not modifiable. You can also set up default views, show dims and load commonly used symbols in templates.
In Reply to brian canavan:
