I am trying to add a construction circle into my drawing. This is to match a manufacturers specification for a port. Attached is the spec. There is a 3/32 gage ball callout and I need to copy that spec exactly in my drawing. I created a sketch in my model with a circle in that spot and it comes up in my view. But, I want it to be a construction circle with dashed lines so it is not confused with other features. Any help would be appreciated. Thank you
RMB on the sketch, select properties, select the linestyle you want it to be.
