Adding jpegs/tiff to drawing borders
Visitor
How do I add jpegs/tiff files to a custom drawing border? I need to add a company logo to drawing border.
5 REPLIES 5
RE: Adding jpegs/tiff to drawing borders
I put ours on a drawing template using insert> object> create from file> browse then select the jpeg/.tiff you want.
Thanks. I tried that, but when I inserted the file, it does not show up in the template.
Did you try to open the jpeg/tiff w/ windows and save it as a .bmp image, then insert it?
Ok, got it come into the template, but the size is way off. It also does not show up in the template unless I click on it.
Re: Adding jpegs/tiff to drawing borders
Vote up this Idea so PTC fixes this issue:
http://communities.ptc.com/ideas/1761#comment-6929
