Adding multiple dimensions in one dimension in Creo 2
ptc-1773724
1-Newbie
What I'm trying to do is add the through hole and counter sink dimension information to the through hole dimension. I've tried using the "&" and "@" symbols but that didn't work. This is the information that I used:
Through hole dimension name: add1
Counter sink diameter name: add2
My text string looks like this: @D THRU, C'SINK &add2
This is what I get: .140 THRU, C'SINK &add2
If I shorten the "add2" to "d2" it get the thickness of my sheet metal part. Don't know what the connection is there.
Any help would be appreciated.
1 ACCEPTED SOLUTION
I know nothing about Creo 2, but in WF2 & 4, you can only use Shown dimensions as parameters in that way, not Created dimensions.
The 'add' prefix suggests your CSINK dimension is a Created dimension.
Unless, of course I'm wrong...
4 REPLIES 4
Thanks! That was it! I added the Shown dimensions and was able to get what I was looking for.
Good! Glad it worked.
You can use Created dimensions this way, but not in a dimension. You can create a note with a leader and have the text of the note be "&add1 THRU, CSINK &add2"
