Adding views in creo and floefd
ptc-4410620
1-Newbie
I started using creo and floefd on a different computer and I noticed that when I tried to change views there was no right side, front side, top, and bottom views. How do I add these views?
1 ACCEPTED SOLUTION
6 REPLIES 6
Hi, to get this into the correct context ... can you please add which product you are refering to?
Creo Parametric, Creo Direct, Creo Elements/Direct Modeling Express 4.0 or the professional
version of Creo Elements/Direct Modeling?
A help here would be appreciated.
Hi, I am using creo parametric. I think the part was modeled without using a template (which was modeled before I got it) and now I want to edit the part. There is only one view which is the front view.
This session will be transfered to the Creo board to be routed correctly - this board here is about Creo Elements/Direct Modeling Express
Where is the creo board located?
Thanks Kris
