Can I view an animation created in Creo parametric in Creo View Express.
I can see there is a some playbeck buttons in Creo View Express but I don't know what files I need to export from Parametric to be able to view animation in View Express.
John
Creo View Express can view
1. Animations authored using Creo View (i.e. Creo View Animator)
2. FRA files from Creo Parametric
Madhavi
www.vizpundit.com
Madhavi
www.vizpundit.com
Thanks Madhavi.
I marked the post as Correct to signal the thread is answered
I tried to open a FRA file with Creo View Express (version 10.2.30.26) but was unable to do so. The error message said that file format was not supported.
